FRONTPAGE Lian Li Launches GALAHAD 240 and 360 AIO Coolers
31 July 2020 - Today, Lian Li launched its first closed-loop All-in-One Liquid Coolers, the GALAHAD 240 and GALAHAD 360. This pair of coolers are available in black or white with 400mm long color-matched, braided tubing. A unique triple chamber pump works in conjunction with the high-density aluminum radiator to keep your CPU temps in check and the addressable RGB lighting keeps your PC looking cool.
Click here to view the article.
Interesting, way too much rgb imo curious to hear about performance
Aluminium rad?!?
Did something major happened the past 2 years that now that AIO mix metals?
Aluminium rad?!?
I saw that as well, had to look at the listing on Newegg and verified that it is a copper cold plate (as expected)
Isn't ek selling aluminum stuff now too? Not to say that's a good thing. I'll stick with copper/brass personally.
They do, but they also strongly advise not to mix both metals.
If you have time to kill...
https://www.ekwb.com/blog/aluminium-vs-copper/
Edit: this being a closed loop, Lian Li certainly use some anti corosive liquid. Still, I would not use it..
Good review from TechPowerUp though
https://www.techpowerup.com/review/lian-li-galahad-240-aio-liquid-cpu-cooler/9.html
