jamesfritchie
- Mar 23, 2020
i just recently had someone finish a full EKWB custom water loop.
Once i received my build, and fired it up i noticed that the pump on the distro plate wasn't flowing all that much water.
I'm using the new EK Loop Connect to control fan speed, RGB, and pump speed.
Unfortunately, no matter what i do to adjust the pwm speed, the pump stays on a low speed and doesn't also show an rpm speed.
I also tried to connect the pump to the pump header on my mobo and the pump stays on the very low setting and hardly moves any fluid.
Do y'all have any clue what might be the problem?
Maybe i just have a bad pump?
