Hello everyone! After a couple of weeks reading and watching tutorials I think I'm confident enough to build my first loop.
pc components are:
Case - NZXT H440
MB - ASUS MAXIMUS VII HERO
grapchics - 2x EVGA GeForce GTX 780 Ti Classified Hydro Copper
DDR - Corsair Vengeance 16gb 2400 mhz
PSU - EVGA SuperNOVA 1000 P2
CPU - Intel Core i7 4790k
SSD - 2x Samsung 840 120gb
HDD - Western Digital 1tb calvair black
1x Corsair Air Series AF140
and 3x 24" monitors
as for the loop I will want to water cool the cpu and the 2 gpus
components are:
pump - Swiftech MCP655
reservoir - Bitspower Z-Multi 250 mm
radiators - 2x Swiftech MCR320-QP Res Rev 2 cooled by 3x Noctua NF-F12 PWM each
CPU block - Swiftech Apogee XT
tubings - XSPC HighFlex Hose UV 19/13 mm
fittings - Koolance Fitting 19/13 mm
liquid - innovatek Protect IP
killcoil
I'm aware that distilled water might be a better solution but I think I will try with innovatek liquid because it have some very good properties.
I was thinking for a loop that looks like res>pump>rad>cpu>rad>gpus>res
my questions are:
Will 1 pump be enough for the loop ?
Do I need 2 loops ?
Is my loop optimal ?
Will I need second psu for the pump only ?
Do I need to put killcoil in the reservoir with liquid other than distilled water?
Are those reliable components?
Should I order the stuff or should I change something ?
any tips will help me.
Thanks!!!
pc components are:
Case - NZXT H440
and 3x 24" monitors
components are:
killcoil
my questions are:
Do I need 2 loops ?
Thanks!!!
