- Feb 9, 2005
Sometimes the rating of the fans are not correct, make sure to do research on the fans. I try and always stay away from noname ones.
Panaflos are great, but only if you need some serious CFM, or you could even go larger with Denki which are totally not needed in your setup. If you still want to try some fans, would just get some cheap $5 yates from jab-tech and try them out see if there is a difference.
I know a lot of people who buy LED fans, and sacrifice color and look over performance.
Good luck.
Good luck.
