Yeah, sorry, I guess I had a typo and wasn't too clear. For a one-off part, they can work from anything (dimensioned PDF, napkin sketch, etc...) 3dsmax is fine for many things, it could even provide you with a dimensioned isometric drawing, which is very helpful for the mill operator. CAD/CAM software is a sure fire way to get EXACTLY what you submit to them, they drop the file in and do nothing. The software optimizes the code for passes, speed, and tooling to produce the exact part that was submitted, in the fastest possible time. I guess I was simply trying to say that there is less operator interaction, less labor, less room for error if provided with the correct model file format. However, this all depends on the whether or not the company even uses CAD/CAM and the program that they use. I guess it could be possible, that 3dsMax transferable into some software
. Just not any that I know of. It would be a good question for the shop you send it to.
Ask if they utilize a CAD/CAM software, would it help to provide a model in that format, and if so, what file format. Most companies don't require it, because they actually want work, and don't want to exclude people that do not have access to $5000+ modeling software. If you were going to actually hire someone to make the part for you (not your brother-in-law
) I would suspect significant cost savings by providing a plug-n-play model, that requires nothing on their part. Other than tooling changes.
I can measure the Heavy and Speed bases from the Gemini (when it gets back from the party), if you want to compare to it.
