Designs with a relatively low amount of mass in the dead center have historically not fared well.I agree that having a layout with a center hole probly better utilizes the space above the center of the die
Would making it a 2 piece allow the machining to happen?Reverse stepping, although at that height it will be impossible to machine.
What about holes on the EDGE of the pot as opposed to the center keeping more mass directly above the CPU for stable temps?
Herm...well we're back to the post idea, which means it'll be slow to respond when poured into i think...that design also takes off a bunch of mass...I'd be interested to see analysis of both of them compared.
I think he's saying to leave mass above the die by simply not drilling but a post is not necessary and may turn out to be excessively difficult to machine.
Sometimes simple is all that's needed to get the job done. If you must make it complicated though, like I said, something inverted (though less exaggerated) than your design in post #141 would probably do well. I'd deem it mostly unnecessary, but it might help the overall feel of the container slightly.The only reason for the steps G, was due to the fact that I don't like boring, lol, and am always a bit difficult. You are most likely right that you can get the same performance from a much more simple design. But then it would be just that, a simple design. A copper slug with a few holes drilled toward the bottom of it. And yes, I'm aware that most everything has been done before with regards to a Copper LN2 pot and this isn't even my pot
I fail to see how this design decreases mass... In the previous design, this shape was flipped over and cut out of the bottom, now it's the exact opposite, resulting in more mass, directly over the center.
Maybe I'm just crazy.
looks like we've cut out 2 times the mass of the stepping to me.
we've gone from 2" of solid copper with holes in it and stepping above it to 1" of solid copper with side by side stepping and holes...looks like we've cut out 2 times the mass of the stepping to me.
