- May 15, 2006
My Windows 7 install is long overdue for a reinstall, but I'd like to prolong that as much as I can.
I'm having an issue with LogMeIn that I didn't have before. Without changing any software (to my knowledge), my computer was getting stuck in "Aero Basic" (AKA: Ugly mode) after remoting into the computer. Even restarting would not fix the issue. I ran the "Aero troubleshooter" and it said the "LogMeIn Mirror Driver" was preventing it from running normally. If I disabled this in the Device Manager, restarted and re-enabled it, it worked fine until I remoted in again. I found a "solution" that says to just leave this driver disabled since it isn't needed to remote in (what is it for then?). This did solve that issue.
In conjunction with that video issue, the sound on my system start "breaking" when listening to music. I'm using Foobar2000 as the media player, FLAC audio files with a 5s audio pre-load. Meaning, it isn't that the server can't keep up. If I restart, it fixes this problem.
I like LogMeIn for its simplicity, but the troubles I'm having more frequently with their product makes me want to not use it. So, if we are not able to resolve these issues, I'm looking for a different way to access my computer.
