Hello all, first post here. I commonly frequent some other forums, but it seems like the watercooling resources on this forum are really great. I've read through all the stickies and I feel like I've put together a pretty good build, but I'm looking to see if anyone has some advice on what I've put together, and perhaps some advice on anything I could do to make it a little less expensive. Right now it's tallied to be $467, which is a little bit higher than I originally wanted.
My goals for the setup:
1) Cool an overclocked 2600K, 4.8ghz or so.
2) Cool an overclocked GTX670(Or potentially a 7950).
3) Quiet under idle/load (<1000rpm fans)
3) <$500 shipped, ideally ~$400.
Here is what I've put together so far.
(I own 120mm fans, and a fan controller)
Pump: MCP35X $99 This seems to be commonly regarded as the *best* (if you can say something so definitive) pump. Looks like it would be able to handle any future upgrades, and being able to control it via software is rather nice. (Can tell if it fails too).
CPU: XSPC Raystorm $50 This block seems to be a nice mix of high performance/low restriction/relatively low cost.
GPU: XSPC Razor GTX680 $90 I cannot find much information about this block, but looking at the reviews for previous generations it seems to be about average, not the best, not the worst, but it has the advantage of being the cheapest full cover block.
Res: XSPC Dual 5.25 bay: $48 Seems to be a fairly generic bay res. I'm somewhat leaning towards a bay res as my case has no windows, so it would be nice to be able to see the water level without removing the side. I didn't go for a pump/bayres combo as it seems that this can lead to being a nosier setup from a not isolated pump.
Rad: XSPC RX480 $120 Definitely the priciest part of my build. But with my goal of low noise, this seems to be a great rad for low speed fans.
Extra Barbs: $8 For the items that don't come with barbs.
Tubing: ClearFlex 60 1/2ID 3/4OD 12ft $17 Seems to fit the bill and is cheaper than most tubing, my case is pretty large so I can handle some larger bends if this isn't the most flexible tubing.
Kill Coil: $7
Lian Li Case wheels: $28 Pretty needed as I want to bottom mount my rad, and these will allow my case to have some space under it.
After looking at this, any ideas of how to make it a little cheaper while still being effective? I have some of my own thoughts here.
1) Use a vario D5 (Koolance version with tach sensor). ~$77. This would save me $23 or so. I'd still be able to manually control the pump speed, and I could sense the rpm to make some safety layer. I'd lose PWM, and some pump head pressure.
2) Use a cheaper rad! like the XSPC EX480 or EX420. ~$75. This would save me $45, which is noticeable, but it seems these thinner rads need higher rpm fans, resulting in more noise. I have some 120mm yate loons, but if I went with the 420, I'd have to buy some 140 yate loons for $20 or so, so I'd save a little less with the 420.
3) Axe the bay res as they seem to be a little bit overpriced (imo), get the swiftech mcp35x res $30, or the micro res if I got the D5. This could save me $18, but I would not be able to see my water level without removing the side. But it would be easier to fill up etc.
Thanks for any help you can give.
Kill Coil: $7
