Skullman85
- Nov 24, 2013
Hello,
This would be my first post here, since i finally am able to build a new rig, anyways is been a while since i built one and wanted a second opinion. The build i am aiming for is:
CPU: AMD FX-9590 Vishera 8-Core 4.7 GHz Socket AM3+ with CCorsair Hydro Series™ H110i
MoBo: ASUS ROG Crosshair V Formula-Z AM3+
RAM: G.SKILL Ripjaws Z Series 16GB 240-Pin DDR3 SDRAM DDR3 2133 (thanks Kenrou for your help)
GPU: (2x) ASUS Radeon R9 380 STRIX-R9380-DC2OC-4GD5-GAMING 4GB 256-Bit GDDR5 (air cooled)
PSU: EVGA 220-P2-1200-X1 80 PLUS Platinum 1200 W
Case: Fractal Design Define R5 Blackout Computer Case
Storage: Corsair Force 3 SSD ATA (for OS) and WDC WD ATA 1 tb.
Right now my main concern is that my GPU and CPU work well with the mother board and that my power supply is big enough to handle everything.
I am just getting it set up and sometime in the future i plan to change my GPU from air cooled to liquid, so for now i plan to put many fans haha.
Well i really appreciate your suggestions, Thanks for your time and have a great Sunday!
