Hi All,
I have decided to build a new computer , switching from amd to intel. I am interested in the Haswell-E . I need some advice on the motherboard and power supply. I was thinking to go with the 5820k. Maybe overclocked to 4.2ghz. I will not game with this build but i will use Handbrake on it. Down the road i may want to add a capture card and capture 1080p 60fps. Now what i have been thinking of is as follows.
1- evga g2 550w or xfx xtr 550w . my requirement is a good power supply but quiet. This build will be in my bedroom and run all night with handbrake.
2- Asrock x99m extreme 4 or Gigabyte x99m gaming 5 or evga x99 FTW. these boards are affordable up here in Canada.
3- Noctua nh-D14 SE2011. or if my supplier cant get it then the U14S. Looked at AIO but fans and pumps are noisy.
4- Antec three hundred two case. Was originally looking at the p100 but not sure if it will handle the heat from the 5820k.
I have the crucial mx100 256 for the os drive. and i was just going to get crucial regular ddr4 2133. I am on a budget so i did not want to go crazy but i do like well built products. Also down the road i will put this board in my Plex server and maybe get a xeon 2630.
Any help , advice would be welcome.
Thanks.
Thanks.
