aceforever
- Aug 21, 2018
I have a single custom loop cooling down the CPU and GPU. I have two fan groups for radiators, one fan group for intake, and a pump. I'd love to set custom rpm curves for these 4 groups.
So far I found a couple options:
1. CORSAIR Commander PRO
2. NZXT Grid+ V3
3. Suggestions?
Both the Commander PRO and NZXT Grid+ V3's software doesn't seem to allow the ability to set a fan curve based on a combination of GPU and CPU load/temps.
One alternative is to use the temperature sensors on the corsair commander pro to hook up to a coolant temp sensor and drive it that way.
At this point I'm hoping to get some advice. Thanks!
2. NZXT Grid+ V3
3. Suggestions?
