- Jan 9, 2006
- Thread Starter
- #21
i prefer them to be the same size as the ones they replaceDoes the fan need to be exactly 92 MM?
If you are planning on using the PWM signal from your GPU, do not expect to have accurate fan control at all unless the fan RPMs are the same as the stock fan the vBIOS raises/lowers the PWM till it sees the fan RPMs it expects
I tried to find a ideal solution, but as of now i am using the fan control switch built into my Define R4 case
https://www.overclockers.com/forums...ntrol-issue-hall-event-duplicator-work-around
BTW if want to make the most of your power limit in addition to powering the fan via sata/molex turn the rgb leds off they are a waste of power
weird it seems to be working fine with the arctic accelero extreme 4 fams and they're about 1000 rpm slower than the stock ones. I just use msi afterburner to control them. it shows the speed as a percent and i just mess with it until i'm happy. honestly though, if it does automatically run them at stock speed that's fine. 3000 rpm isn't that loud at 92mm and that's what i was going to set them to, give or take. the parts will be here some time in the next week so we shall see.
PS: definitely not using leds since my case has no window anyhow.
