- Nov 24, 2011
I swapped out my cooler and the vbios is confused as how to handle the new fan, even when using a custom fan curve it seems to panic during idle at times and ramp the fan speed up
it seems the vBios controls the fan PWM % based on the fans current RPM relative to what it expects instead of doing the sensible thing and setting the PWM % based on temperature curve
well the stock fan was a 3000 RPM fan and my new cooler uses a 1500 RPM fan, so if there is some way i can generate 2 pules for each 1 pulse the vbios will see a RPM in area it expects to see and hopefully not panic.
any ideas on how i can make trick the card is to thinking a fan is spinning at 2x speed?
this would be so easy if you could just alter the bios on 10 series cards...
