Question, why are all the fans exhausting?
You want negative pressure?
Why go though the trouble of a custom loop and not optimize the airflow cooling your rads?
I do not know much about water cooling but from what I've read, all fans on exhaust is not optimal, no matter the cooling method. Someone educate me otherwise please.
I wasn't aware the case only held four fans. I'm assuming it holds at least double that. I don't see the top front or rear fans set up yet.....
Why not? There really is little difference in most cases. Positive keeps some dust from coming through the cracks, but otherwise, in my cases and experience of the last decade, I preferred more CFM exhaust than intake (though barely).You want negative pressure?
Unless that one intake is a monster of CFM, you likely have just described NEGATIVE pressure or more CFM exhaust than intake.From my own experience w/ having 3 rads, having positive pressure (1 rad intake 2 exhaust adjusted by fan speed) makes a very large temperature difference. The PC needs to fresh air coming in so that you actually have some air to exhaust, otherwise you'll just have spinning fans that are struggling.
This!!!But the user already explain it's a mock up and he plans top rad intake, but i still would prefer to have the bottom fans in pull (intake) config and the top in push (exhaust), just because hot air naturally goes up.
I have seen other pictures on his topic here, and top fans where exhausting and he's going with a res/distro block that covers all the front area (in this case actually he is putting it on the back/side drive bays area since the front doesn't appear to have mounting holes and its closed), so that is why i made the question.
But the user already explain it's a mock up and he plans top rad intake, but i still would prefer to have the bottom fans in pull config and the top in push, just because hot air naturally goes up.
Fresh cold air intake rad-less fans is the way to go for fresh air.
