Ok, talking about the fans ... I'm feeling a bit in over my head and not sure If I know what I'm getting into quite yet.
- My Phanteks Enthoo Luxe case has a PWM hub, supports like 8 fans, each of which has 3 pin connector on it.
- I have an Asus Rog Frontbay + Asus Rampage V.
- I am going to be putting several Thermaltake Riing RGB's into the case (1 on GPU rad, 4 on CPU rad, 2 in front of case) - which require using their own little hub (supports 3 fans per).
- Going to either use a NXZT Kraken X61 or Corsair H110i GTX.
... Ok, now the million dollar question, how does it all go together?
Some questions that come to mind:
1) Can you daisy chain the Riing's? There's a second 4 pin connector which I'd assume is the purpose of that? Nothing in the manual about what purpose that second 4 pin port does.
2) Can/should I use the case's hub to bring ALL the fans together?
* I'd assume there's a limit of power on whichever fan port I connect it to right?
* I'd think this is probably a bad idea as I wouldn't have granular control with the Front Bay right?
3) When using said Riing's (4 total) on the CPU radiator, will it be a problem hooking up 4 fans to CPU_FAN, or should I split 2 off to CPU_OPT?
* The manual says CPU_FAN supports the CPU fan of maximum 1A (12W)
* Unless I can daisy chain the Riing's, I think I'd have to split them up in 2 sets of 2 (the TT hub supports a max of 3)
4) The case's hub says it's supposed to go to CPU_FAN. In the event I'm using that and/or CPU_OPT (based on #3 above) ... does it matter where the case hub goes?
* I'd assume they're planning on you hooking up the heatsink's fans to this hub and that's why they say to use CPU_FAN?
* In the event that I'm plugging the CPU rad fans into CPU_FAN and CPU_OPT, this only leaves 3 fans that need to hooked up, so I'd probably say skip the case hub in favor of having the control with the Front Bay.
5) The Corsair has its own built-in cabling for the fans, will bypassing these be an issue?
6) What if anything do I need to take into consideration for leveraging the Rog Frontbay properly outside of a couple of the aforementioned comments?
7) Do they make extenders for 5 pin fan connectors? The Riings use them and in order to hide these hubs, I'm going to need some longer cabling.
I know I'll fat finger my way through this, but I'm just scared of **** blowing up. Would love a sanity check on what I'm doing. Would be insanely appreciated!
Thanks all
