- Nov 24, 2011
My motherboard has this slot "M.2_SSD (NGFF) Socket 3, supports M Key M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen2 x2 (10 Gb/s)"
I can use a M.2 PCI-Express 3.0 x4 in this slot but it will only perform at ~800MB/s correct (given the ssd is rated above that)? On the plus side this will lower the max running temp right?
Alternatively I can use a addon card adapter and get full speed, however I do not want to restrict airflow to my gpu
Now I do recall seeing mining rigs that use cables on the pcie slot to get more space between units
If I can use a cable i could simple mod the way the card sits on the bracket and place it over a PCI slot and not restrict the airflow
possibly even rig it onto a 2.5" hdd slot if the cable is long enough
Suggestions and part recommendations?
I could place it above my gpu, but i have my Ethernet card there (onboard lan does not support WOL in linux)
