- Apr 20, 2004
- Houston Tx
I have the above (corsair Model CMX4GX3M2B2000C9), but AMD overdrive is listing my memory clock speed as 667 MHz. Shouldn't it be 16000MHz?
Thats its naming convention, not its speed. Its speed is actually 2000Mhz (which AMD likely wont run it at). So with that said, just set it at 1600Mhz with the right timings.
Trents would know better than me, but, I thought AMD had A LOT of trouble hitting DDR3 2k memory speeds...or am I mistaking? I know you would haev to give the CPUNB more volts to hit DDR3 2k speeds.
Trents? Am I off? Just set his to 1600Mhz @ 1.65v and cal it a day?
