well i was thinking the same thing about the lga775 mounting. then my mind changed when someone posted a link about that with lga1156 on the same board. since intel is using a different height hold down for the cpu. they said it was best to go ahead and come up with a new mount due to the height change.
which got me thinking if i used the LGA775 mount from my WB. what if i dont get the right contact, prolly like im getting now with my ninja on my 920. i have had this cooler for so long, i thought it was a blessing to be able to keep using it. sad part is the AC7-pro gets better temps on my rig#2 then the ninja ever did and is just as quiet as the ninja. not only that i was able to push the E7200 up to 3.6ghz from 3.4ghz, though i never changed my sig. the temps on the
[email protected] are the same i was seeing at 3.4ghz on the ninja. which is 60-62c load, running rosie...
now adelphia83 i have gone back a few times now, what cpu have you settled on? i only ask cause the 860 i bought from newegg came with a free CM TX3 with LGA1156 mounts. not the best cooler but better then intels stock one for sure. if you are getting the 860, you could use the TX3 till Tuniq releases a LGA1156 mount for the TT.
consider this about LGA775-LGA1156 mounting.
http://www.ocforums.com/showpost.php?p=6231608&postcount=14
http://www.ocforums.com/showpost.php?p=6232166&postcount=23
im not saying cooling is going to be horrible. there are things we as oc'ers if ocing need to consider first. is that board going to be worth it if the cpu is being cooled as good as say if it where a true lga775 socket. just food for thought, that's all.
