- Jan 14, 2006
Well 1st Of all i want to say hello to everyone and sry i haven't been i around ,and i will explain that to the Benchmarking team as i did with Johan
Im writing this after I have had my System up and Running FULLY without issues plus i have to edit some pictures as some are way to big sry and did some system updates
i also did put my system in Mods Rigs on EVGA Site ,i was told this was ok to ask this cause i wasn't selling anything and i wasn't a spammer .plz check it out as im trying to get 1k EVGA Buck sponsorship so post a comment below @
http://www.modsrigs.com/detail.aspx?buildid=36087
Sponsored By Swiftech
Hello over the Last 15yrs or so , i was a AMD fan ,i have finally made the leap to intel with the help and support of my Wife
So off to Neweeg I go ,so i thought i would start of with getting the case 1st that took me about 1 week to find ,so i went with a the Phanteks Enthoo Pro.
The Reason i went with this Case is because to me its low profile ,Black ,window and you can hide the USB ,Mic ,headphone jacks and reset button ,it has plenty of air filters and alot of room for fans and liquid cooling
another reason why i like this case is the Cable management and the two SSD Brackets on the back of the motherboard tray ,removable HDD cages and its a full tower ...GOT it for $99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811854003
something was missing on the case so for the next 2weeks i went looking for a decal that i wanted to put on my window ,i didnt know what i wanted but i found it ,it is a Grim Reaper Nevermore ,1st Picture of course is the original
My first piece of hardware i got was the motherbord, to make a long story short was an Asus board ,i was unhappy with it i did a full refund rma, the reason is that only one RAM slot worked
So i went with Another board and that was an EVGA z170 Classified k , i went with this board after a friend recommend it to me plus i never had one problem with EVGA products , i like this board after looking at it over and over, is the M.2 ,Onboard power, reset, clear cmos buttons and the dual bios and it matches my color scheme of my system
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188181
Well the CPU was the next thing i didnt need nothing to big so i went with the 6700k just incase ,i know it can be overclocked and it will handle any game ,to me anything higher then this would be a waste of money so i put it else where
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117559
Then ordered myself an EVGA 1070SC Black Edition to replace my EVGA 970 FTW+
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487265
I also want to mention that the cooling on both CPU and GPU are cooled by Swiftech Products. Who I am also sponsored by.
CPU COOLED BY H240 X2 Prestige
http://www.swiftech.com/h240x2prestige.aspx
GPU COOLED BY KOMODO NV-LE-GTX1080
http://www.swiftech.com/KOMODONV-LEGTX1080.aspx
Next was the RAM, I went with G.skill like i always have in the past and i have been reading the reviews from the forum that im a part of overclockers.com, so i went with the TridentZ
http://www.newegg.com/Product/Product.aspx?Item=N82E16820232306
Forgot to get pictures of the ram i will edit and get them
Ok the final piece to get the PC up and running is the PSU ,i got a good deal on the PSU I got i know it way over kill , but atleast i have it just incase ,and its a Corsair RM1000 got it for $175 now its over $200
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139057
no Pictures of PSU
Got a Sound BlasterZ sound card cause i don't like onboard sound
http://www.newegg.com/Product/Product.aspx?Item=N82E16829102048
Also got two 32 inch TV's in 720p for a great price for under $125 each
https://www.walmart.com/ip/ProScan-PLDED3280A-32-720p-60Hz-D-LED-HDTV/46368139
these are the pictures of me tearing apart the 1070 and putting the Swiftech water block on
If you noticed i have to put the card in this slot cause of the O/I shroud the reason is here to why i did what i did
if you look all the pictures closely you can see i had me reasons
http://forums.evga.com/Z1...O-Shroud-m2602901.aspx
If you look closely the bottom of the I/O shroud would block the GFX from sitting properly so therefor i would have to place it in the next slot down for now
This is the 1st Time doing a log not sure if this is how you do one but I'm proud of my system , what do you all think
Updates:
Changes
Cut the bottom of i/o shroud so gfx could fit now mind you ,look at that picture (4th) and see how close it is to the GFX crd after cutting it
Case:
I have Swapped out my Phanteks Enthoo Pro Case for the EVGA DG-86 Case ,cause when i got it ,it went on sale for $149.99 and its a lot bigger then Phanteks Enthoo Pro and has more options for water cooling
Front Side
Left Side
Right Side
Back Side
Temp Inside the Case only
Front Side all Red
CORSAIR Lighting Node PRO
HyperX Cloud II 7.1 Virual Surround Sound
no Pictures of PSU
Updates:
Changes
Case:
Front Side
Left Side
Right Side
Back Side
Front Side all Red
