Does anyone have a Circuit Schematic for reading the output from the RPM signal wire?
I care to wire something up that will read that wire and output the Rpm to an LCD).
Additionally, if it's net economical to do so...ie it'll cost far more to fabricate than it would be to just buy a controller with readout.
Time isn't a factor, you can negate that. Nor do you need to factor in tools. I have a sodering iron and all that whatnot. Just factor in raw materials.
I havent googled yet but I'm thinking the little LCD screen buddy might cost a bit.
Anyhoo goal is to output the RPM to an lcd to be mounted in a 5in bay
Thanks!
PS No, i'd care not to build an RPM sensor using a IR sensor or a photo sensor to count the gaps between the fan blades. Just want to read the RPM signal wire output.
Thanks!
