10XTriplet
Disabled
- Aug 20, 2012
Sorry if this is in the wrong place; move it if it is..
This seems a bit off the wall, but I did some research and would seem like its possible..
I stumbled onto this idea when I asked about peltier coolers here. You can generate power if you add cold or heat to either side, the device will generate power. Sounds a bit crazy, but there are many video's all over youtube showing how this is done. My thought is to go large scale with this. Making a 2 x 4 foot peltier heat grabber, then maybe the part two to this would cool your attic space by blowing the cold side into your vents. A guy on the web tested different paints for the best solar absorption. I found a place where I can get aluminum sheets in pretty much any size I would need. I found the largest peltier I could find, and how hot the hot side gets (source), about 158 deg F. Now, from my research it would seem the sun can get the aluminum to about 160 degrees F, which is right where I need to be.
Now I was thinking to get 545 watts, I would need to achieve 160 degrees on the hot side to produce good power output. I've done alot of research on solar panels too. The best is Sharp. 240w panels. A single Peltier kills that, if this idea can be done and alot cheaper. If I would to put a few of these in a parallel configuration I should be able to achieve alot of power @ 12v, then send this to an DC to AC converter, and there you have it... A home made solar panel...
Your thoughts?
Your thoughts?
