10XTriplet
Disabled
- Aug 20, 2012
- Thread Starter
- #21
No IMOG is correct, you have to cool the cold side, the pelt won't do it for you.
You need to have one side significantly hotter than the other to get power out of it.
If you put power into it, one side will get cold and the other will get hot, but of course you can't put power in and take power out
The CPU will fry, pelts don't conduct heat will enough. The CPU will overheat because the heat cannot get through the pelt to the heatsink/fan.
They don't conduct heat for beans.
The can actively pump it if you pour a lot of electricity into them, but that is a different story.
Ok, I see your dilemma. Did you watch the video? Still no power added on either side. But when you do add power one side gets cold the other hot, but if you apply hot to the cold side, and put a heat sink on the other, it generates power.. So you would put large heat sink on the cold side and an aluminum plate on the other coated with flat black paint... put it in the sun and see what it can do.. simple as that..
here is another video
