- Oct 14, 2012
I have an ultra and if if the card cost more than $125 i would never think about plugging it in.
My OCZ 1KW Fatality was 100 bucks... and I would throw anything can get my hands on it... even have an extra one
Tried getting my memory up to just 1125mhz earlier. Crashed like usual. Anyone want to give it a run with your HTPC card so I have someone to be competitive with?
Single|jiccman1965|EVGA TITAN|Water|7470.775
Took everyone's advice and slowed everything down, GPU clocks and CPU everything was on Auto at 4.8GHZ.
Well done man!
Sometimes less is more.
I changed my config some, will try to increase score a bit higher just in case you get froggy .......
Here you go, i will take my seat in the cheap section please
Keny|single|8800GTS|Stock|952
You might need to try removing the GPU and running the 3570K's integrated
It does have integrated, right?
I told you you wouldn't be alone at the bottom.... For the record, I hate 3D benching, hence that's why I have no decent gpu's, if it puts a picture on the screen, its good enough for me
I do want those gold cups back.
qlix, you making any headway?
Nope. None at all. Flat out doesn't work. I'm beyond confused.
bmwbaxter said:You can learn some tips and tweaks, plus see how your scores compare.
No pressure, just overclocking, tweaking and fun!
