- Aug 14, 2006
MetalRacer | GTX 780 Ti | Single | Air | 4101.128
Check to make sure it is not hitting the low power limit and throttling because of it. If temps are under 80C (or you can raise that limit), its not temps. But you will need a log/graph like MSI AB has (I think Precision X does as well) to see if the clocks are actually holding.I still trying to figure out the boost in evga precision... Running stock it boosted to 1124mhz under load and when I added +75mhz it was reporting 1228mhz under load. It doesn't make sense to me it's almost like it just boost itself to a maximum level automatically. I have set the TDP to 106% maybe it is just going to that level and stopping because with an offset of +135mhz it still stopped at 1228mhz.
Try +135 GPU and +125 MEM @ 106% also @ 80c and if you want to you can add some voltage as well PB!! When you do the 106% and the Temp you need to break the link by clicking on it with your mouse!!
That should make it work!! Just forget about BOOST it does that like AUTO!!
Concentrate on your MEM CLK + your GPU CLK!!
AJ.
Well, on my 770 review, It did boost around 40Mhz only...so that is likely normal. Now, Shrimp's 780... that is what I want to know what the boost clock was.
http://www.overclockers.com/MSI-GTX770-OC-graphics-card-review
41K... World Record!
Nice run!!!! MONSTER clocks on that 780ti... what was the actual boost clock for that run? And was this chilled air on the card?
Nope.. all good! The end game for me was to see what it was. I have a lot higher clocks but still can't reach that score.
Did you do any tweaking on it?
Shoot.. missed you had that in your ss... My bad.
I need to get a skynet bios on my 780 so I can beat shrimpy...
And then I need to push this 290 to beat you..lol. But, not sure it has it in her on 22c ambient and the core craps out at 1228 it seems. Bleh.
Try this to help you out SB BUDDY!!
1, http://www.frozencpu.com/products/1...onductivity_170_WmK.html?tl=g8c487s1797#blank
2, http://www.frozencpu.com/products/1...rmal_Conductivity_170_WmK.html?tl=g8c487s1797
Its been said to help with Temps as much as 20c on certain cards etc!
AJ.
