- Nov 26, 2005
- Concord, NC
I was thread jacking again!
Decided to move it to a new thread.
GotNoRice said:My overclocked B3 is also at 3.3/1.38v and my load temps are about as high as yours. Under prime95 the temps will go over 80C but everything remains stable. I ran for 48 hours just to be sure (24 hours just prime95, and 24 hours also using ATi tool to heat my GPU/test power consumption).
My idle temps right now are 50-55c between the cores. This is using coretemp; speedfan reports temps ~15C lower which I consider inaccurate.
Max thermal spec for a B3 is 62C TCase which should be about ~77C from the TJunction sensors, so 80C is not really "out of the park" in terms of temps, especially in the artificial scenario of loading all 4 cores using prime.
I'm pretty sure my heatsink is installed just fine, and it is still an improvement over the temps I was getting with the stock heatsink, which I'm 100% sure was installed correctly. I used AS5 and followed the instructions to the T.
I look forward to lapping my CPU soon to see if it makes any difference.
jason4207 said:Is this true? I haven't heard anyone else say this yet. So does this mean you can run a G0 Q6600 up to ~86*, and a G0 x3210 up to ~100*?
I had assumed you wanted to keep your temps (as read by TAT, CoreTemp) below the thermal specification.
I understand that the TCase and the TJunction are 2 different areas of the chip. I guess I just assumed that the Thermal Specification was related to where the sensors are actually located.
And you're saying TCase, and TJunction run with about a ~15* delta?
Can anyone back-up or deny GotNoRice's claim? I'm very curious.
GotNoRice said:Yeah. The x3210 is probably trying to account for rackmount enclosures, etc where temperatures could get hotter. Technically a processor should be able to sustain any temperature below the actual TJMax of the processor, at which point throttling should occur. As long as everything is stable there shouldn’t be *too* much to worry about.
TJunction sensors are located on each core. Quad chips don’t actually even have a TCase sensor anymore, but intel still outlines the procedure for measuring TCase temperature; it involves cutting a groove into the IHS and placing an external temperature sensor in the approx center of the IHS. See: http://www.overclockers.com/articles1312/8052.jpg
The difference between TCase sensor measurments and TJunction measurements are typically about 15C under load; it’s simply hotter on the cores than on the IHS.
Brollocks said:Read this thread, it will make it clear what the differences are between TCase and the TJunction etc
jason4207 said:Just to clarify...
If I have a B3 x32x0, or Q6600 I can safely run it up to ~77* as seen in CoreTemp.
If I have a G0 Q6600 I can safely run it up to ~86* as seen in CoreTemp.
If I have a G0 x32x0 I can safely run it up to ~100* as seen in CoreTemp.
I had thought everyone on here was trying to keep their CoreTemp readings at or below the Thermal Spec (as listed on Intel's website). This is very good news indeed! Can I get some more confirmations please! I don't want to fry anything!
If this is true I'm going to have to tell my buddy to crank up his B3 x3210 a notch b/c I was trying to keep it under 62* w/ p95 running. I was getting 65-66* at 2.4GHz (1.2v) w/ p95 running, but was still under 70* at 2.66Ghz. He's still running the stock cooler BTW.
Brollocks said:Bing would be the best guy to clarify IMO
graysky said:@jason: dude, you're temps are too hot according to Intel's own specs. Look up your processor at the processor finder to see what the max temps should be.
jason4207 said:Those aren't my temps man...you need to read further up the thread.
Those are "what if's" based upon what GotNoRice posted.
Bing, can you answer this question about TCase and TJunction temps?
GotNoRice said:From that very link, if you look up your processor and then click on "Thermal Specification" so that the details box comes up, it says:
"Thermal Specification: The thermal specification shown is the maximum case temperature at the maximum Thermal Design Power (TDP) value for that processor. It is measured at the geometric center on the topside of the processor integrated heat spreader."
Notice how it does NOT say measured using the Digital sensors on the core? That would be the TJunction temp, which is hotter than the temp at the IHS, typically by 15C under load.
Note: There is a separate issue that is confusing due to the fact that is also involves a 15C difference. Older versions of Coretemp report TJunction temperatures based on an 85C max. B3 and I would assume G0 processors also have a TJunction max of 100C. Since TJunction temps are calculated by subtracting the sensor value from the TJunction max, if the program thinks your max is 85 when it is really 100 it will report temperatures 15C too low. You can see how on the surface it would appear to correlate to TCase temperatures since you’re talking about a 15C difference in both cases, but there is no connection. Version .95 of coretemp should report your TJunction max correctly.
jason4207 said:I definitely believe you GNR. It makes total sense to me. It just seems from my reading that everyone else was trying to get their CoreTemp .95 reported readings to be less than or equal to Intels thermal specification when running p95 or Orthos. I may have interpreted posts wrong, but this is the general feeling I had based on all my readings.
If someone says they are running their G0 Q6600 at 80* everyone would say that is too hot. You are saying that is not the case, and they should be fine as long as their voltage isn't too high. Because too much voltage at any temperature can fry a chip.
I am aware of the problem w/ CoreTemp vs. speedfan temp reporting, and understand it is a separate issue. You have shed some light on a few things I didn't completely understand yet, though...thanks!
Brollcoks said:Would be great if we can get some real confirmation on what max temp the q6600 can take, if it is 80 C then I can pobably get to 4 G's, that would be awesome
Edit...also what is max voltage for this CPU?
jason4207 said:Can anybody else confirm?
Bing said:I guess some of you recognize me for one of the OcFer here that do not trust cpu absolute temp reading using software.
Now, this is about the "other" method to boost your OC morale for squezzing more performance from your current OC if you got scary on the temp you've seen when your OC-ed CPU on loaded, "but" you still don't believe your CPU temp reading accuracy when using software.
Warning ! I never recommend this to everyone, read and undertand the risks & consequences.
If... again a big "IF" you have the gut, my suggestion is find the CPU throttling temp with these following method :
* Put your mobo on bench or table, not in casing, and use Intel stock HSF, also I suggest add few fans to blow on the mobo mosfet and chokes and other parts as well.
* Yank out the HSF fan and hold it with one of your hand right above the heatsink.
* Now, run your favourite temp monitoring program, throttle watching program like RightMark CPU Clock or ThrottleWatch and Prime95 to load the CPU.
* Once the Prime95 launched, watch the temp rising and be prepare another hand which is not holding the fan at the power switch for "emergency shutdown" just in case.
* While watching the program toasting the CPU, watch closely the temp reading and the throttling windows.
* Start swing or waive the fan "slowly" farther from the heatsink to slowly heat up the CPU until it starts throttling.
* Once you saw the throttling started, mark down the CPU temp, this will be your last hottest temp that the "TRUE" Intel Throttling Mechanism (TM) starts to kick in.
* Once that throttling temp is acquired, at this point it is up to you whether you want to turn it off thru the power switch or cooling the cpu by bringing the fan closer to the heatsink and watch the process of CPU cooling and where the throttling stops at.
This will last only for 3-5 seconds when the throttling starts, been there with 3 pre core Intel cpus and they're all still alive today & kicking !
Just "an example" if you captured the throttling temp for your CPU is at 93 C and your current maximum OC on loaded CPU is at 68 C,
Now, the last important question that you should ask your self as an "OC-er" :
"Do you have the gut to squeze more ? Maybe like until it reached 78C or even 80C ?"
Final Warning !
Do this at your own risk, I will not be responsible for any problems or damaged that might happened to your rig.
