what do you mean about g.skill you wont find lower and blue have tighter timing and orange have looser, sorry im a noob.
I meant heatspreader height but you have water cooling so it doesn't matter.
About other thing, for example
ARES 2133 in blue heatspreaders have timings 9-11-10 and
2133 in orange heatspreader 11-11-11. Also these in orange heatspreaders are cheaper.
so do you recommend vengeance ? do you think 1600mhz is enough?and can i overclock it?
Vengeance isn't best series as I already said and personally I wouldn't buy them but it's enough for everything and you won't see special difference between Vengeance and other kits. You already said that some users have issues with Vengeance memory on MVG so better stick to something else.
1600 is enough for games.
and sir i need your expert advice about overclocking 3770k ,what value should i apply in vcore and cpu ratio i'm not into benchmarking score you know i just need to oc it for better gaming btw i'm just using h60. thanks
Raise cpu ratio to x40 and set cpu voltage manually to 1.20V. Run Prime95 ( free for download ) blend test for ~1h. If there won't be any errors then back to BIOS and check x41 ratio on the same voltage. If no errors then x42 ...
Each time 1 step higher. When you see errors then try higher voltage.
Since your cooling isn't best, I wouldn't use more than 1.25V what will be enough for at least 4.2GHz ( maybe higher, depends from cpu ).
Check cpu temperature with
hardware monitor. Try to keep max load temps during Prime95 under 85-90°C. If it's too high then set lower cpu voltage.
You will probably never see 100% load in any game so you can count that maximum Prime95 temp is higher by about 15°C than what you will have in games.
For games 4GHz is enough and what counts more is graphics card speed.
Browse forums for some more results on similar cooling.
