I have a Maximus X Hero w/ i7 8700k and two sticks of 16GB G.Skill PC 3200 kit (listed in QVL for both motherboards).
System would only post with the modules in B1 or B2, and since dual channel configuration requires A2-B2 (or A1-B1), I'm stuck running both modules in single channel. Anything in an A slot results in code CC and post failure. The exact same processor and memory are resulting in the same problem on a new Maximus XI board.
I have followed some troubleshooting steps shared by techs on the Asus forums to no avail, including various BIOS tweaks and voltage settings. I've examined the pins on both motherboards and can see no damage, nor do I find any on the cpu itself. Also, I've attempted to post with the gpus taken out, motherboard screws loosened, and the cpu cooler just resting and not screwed in. Same result.
And unfortunately I don't have extra modules lying around, but have ordered a couple of sticks (also listed in QVL for both boards) which will be here Monday. However, since my modules work fine in single channel mode (B slots), I'm inclined to believe they're fine.
Until I'm able to troubleshoot some more, my question is: could my cpu be causing this problem? Because I've had NO other issues with it. Runs stable and seems fine. I've run intel diagnostic tests on it and everything passes, though I don't know how much stock to put in that. But two different motherboards? Hard to believe they'd both be bad with the exact same issue...
Anybody have any experience with this problem...is there something else I might be missing or could try?
