- Jan 9, 2005
hey, just got two mcp50x, and two of the swiftech reservoirs that mount to the top of the mcp50x.
now, with both the res tops, they come with a little dowel pin that goes into a slot on the pump, and then into a matching hole on the bottom of the reservoir, to keep it locked in place while you tighten things up.
however, when i drop the dowel pin into the slot on the pump like it says to in the instructions, the pin falls all the way in, and does not stick out of the pump at all. this happens with both the pumps, and both the dowel pins, basically rendering the dowel pins useless.
anyone else had this problem?
I've sent an email to the store about this, was just thinking i might hear back from here sooner, maybe someone has dealt with it and knows where to get a little dowel like that, and what size to get.
