Hello,
I built a new PC with the following specs:
Asus Maximus X Hero
i7 8700k
Noctua NH-D15
EVGA 1080 TI SC2
2TB 860 EVO
bequiet Straight Power 11 850W
I tested a G Skill 4133Mhz CL17-17-17-37 and a G Skill 3200Mhz CL14-14-14-34 (2x8GB both kits)
The XMP on the 4133 puts me at 1.4v DRAM, 1.34v VCCIO and 1.3v VCCSA and doesn't pass a 1h test of 1344k Prime95 (however, it passes without XMP being enabled). CPU OC in both cases disabled @ 3.7 Stock. Tried 4.8 as well, no success (CPU OC on its own has no problems)
The XMP on the 3200 puts me at 1.35v DRAM, 1.34v VCCIO (again) and 1.15v VCCSA.
Could this be a sign of a really bad Memory Controller? The CPU looked like it was resealed when I got it (Amazon) but I decided to keep it since I can run stable 4.9Ghz @ 1.28v under full load.
Right now I am testing the 3200 sticks with a manually turned down VCCIO to 1.28v (its set a bit lower in BIOS, shows 1.28v in HWinfo). From what I've seen I shouldn't even need a VCCIO above 1.2 to handle this kind of RAM.
My goal is to be 32h Prime95 AVX with 0 offset stable (no FMA3) @ 4.8/4.9 Ghz and at least 3200mhz 14-14-14-34. If it really is the IMC, should I just return the CPU?
Asus Maximus X Hero
i7 8700k
Noctua NH-D15
EVGA 1080 TI SC2
2TB 860 EVO
