- Jan 18, 2001
- Athens - Greece
Hello guys,
it seems my Mobo is going to be replaced, but let me describe what exactly happen just in case I miss something:
With 6Gb (3x2Gb) or 3Gb (3x1Gb) memory modules @sockets 1-3-5, is always usable in Bios and of course also in OS, only one memory module @socket 3, even if 3 modules are detected in BIOS!?
I Cleaned all mobo, memory slots and memory contacts, visual inspection on both sides not showed any issue, set XMP, relaxed timings, repositioned in a different way rams and using Single or Dual channel mode instead of Triple won't POST. Now I'm using latest F11T Bios, but just to be sure I tested F11o and the situation remain the same... also replacing my old i920 with a x5650
Last option remain is to use WD40 contact cleaner, but what do you think about in accordance to your expertise guys???
Thanks in advance for your reply.
Regards,
Adriano
Regards,
Adriano
