- Nov 3, 2003
- Lake Stevens, WA
I need to upgrade the memory in my system but I have seen a lot of post saying that speed really does not matter for real world applications and I am now unsure which one to get.
Can I get some recommendations on which Memory I should buy if I only plan to run my system at stock speeds, and also a recommendation on which one would be good if I do want to overclock my system a bit? Thank You.
My Primary System has:
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
GIGABYTE GA-Z77X-UD3H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Cooler Master Hyper 212 EVO - CPU Cooler with 120 mm PWM Fan
2 Years ago I bought this memory for my Primary system:
CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ16GX3M4A1600C9B
After I bought it I realized 16GB was unnecessary to run games. The most I needed at the time was 8 GB so I got the same motherboard/cpu and I split my memory so I had 8 GB in each system.
Recently I bought a New Video Card and started looking at the system requirements for EQN Landmark, TESO, Wildstar and I realized that I need to definitely need to start running 16GB in my system.
SAPPHIRE Vapor-X 100351VXSR Radeon HD 7970 GHz Edition 3GB 384-bit GDDR5 PCI Express 3.0 x16
I know my motherboard can handle 32 GB ( 4 x 8GB ) but I do not wish to spend that much for memory at this time. I wish to buy 2 x 8GB to my main system, then i will put all the 4 x 4 GB I originally bought in my 2nd system. Later I will just add another 2 x 8 GB of the same stuff to my main system to bring it to 32.
If memory speed does not matter then I am leaning towards getting the Crucial 1333 at the top of the page which is only $122, but the 1600 of the other brands is only $10 more. I bought this specific CPU so eventually I can overclock it......Which memory should I get? I am trying to keep the price of my 16 GB under $180, otherwise I would just be better off buying 32 GB.
Newegg Memory List:
http://www.newegg.com/Product/Produ...1&name=16GB (2 x 8GB)&Order=PRICE&Pagesize=20
Newegg Memory List:
