Here go my memory woes:
I have 2 modules in my computer, both DDR400 512M, from the same manufacturer (which shall remain unnamed), same part# but purchased 2 years apart. Let's call them module1 (bought first) and module2 (bought 2 years after module1). Until recently they ran fine in dual-channel configuration, even though their specs are not exactly identical. Module1 is DDR400, CL 2.5-3-3-6 and module2 is/was DDR400 CL 2.5-4-4-8, as shown by CPU-Z. The motherboard is an Asus A8N-SLI Premium.
About a month ago the computer started crashing. I diagnosed the fault to be with module2, which tested with several bad locations in memtest86. I contacted the manufacturer, and since I had lifetime warranty they RMA'd module2 and sent me back another module, same part#. Let's call it module3. Now module3 shows in CPU-Z as DDR400, CL 2.5-4-4-8 (same as module2 was).
The problem: now my computer only runs in single channel configuration. It does see both modules fine, and they both tested OK in memtest86 (I let it run overnight).
Things that I did so far:
-ran memtest86 - OK
-tried running the memory as DDR333 instead of 400, same thing happens
-checked that I use the correct memory slots - no problem there, should run as dual-channel but doesn't
-played a little bit with memory timings and voltages in the BIOS, no improvement
Now, the module they sent is good so I can't RMA it. And I don't trust a lot the ability of the manufacturer's tech support to help me (when I sent them the message asking for RMA I stated "I tested it with memtest 86, and the following locations test bad:..." and their reply was: "download memtest86 and run it")
Any ideas? Anyone? Please?
-ran memtest86 - OK
