Memtest86 - next pass much longer than previous. Is this normal?
sew333
Hello. So i bought last days 16gb ram 2x8gb DDR3 1600mhz. I have a question about time of each loop.
1 loop ( pass ) is 13 tests.
The first pass came after 1 hour the 2nd pass came after 3 hours. And next pass will be much longer than second. Is this normal? Thx
Just like every single question you ask, yes your system is fine. It is normal. It will not cause issues. It is not broken.
