- Jul 3, 2006
- UK
That's 3DMark, UT3 can be set at anything, but for me it hits a cap of 62 fps. There are software programs that override this to lets you see the "real" fps you should get.
I can run UT3 in 1920x1440 for example.
Need more info
Just go into your Documents, Your Games, UT3 folder, UT Game, Config, and open the UTEngine.ini file. Then set the first value shown below to false or set the fps limit as high as you want in the 3rd entry.
[Engine.GameEngine]
bSmoothFrameRate=FALSE
MinSmoothedFrameRate=22
MaxSmoothedFrameRate=62
