- Apr 14, 2011
Might be interesting to load up on a spare rig, but not on my main rig after reading this.....
Important
If you decide that you want to install Windows 8.1 Preview using the ISO, you won't be able to uninstall it. If you decide to go back to your previous operating system, you'll need to reinstall it using the recovery or installation media that came with your PC, which is typically DVD media. If you're running Windows 8 and you don't have recovery media, you might be able to create a USB recovery drive. If you're running Windows 7, Windows Vista, or Windows XP and you don’t have recovery media, you might be able to create it from a recovery partition on your PC using software provided by your PC manufacturer. Check the support section of your PC manufacturer’s website for more information. After you install Windows 8.1 Preview, you won’t be able to use the recovery partition on your PC to go back to your previous version of Windows.
SOURCE
has anyone else tried it? how well does it run?
im gonna buy it when it comes out btw.
Yes but windows 8 has no trial period like windows 7. This is a service pack for windows 8, you have to have a key to install win8, the initial installation can't complete without a key.
