Hi I would like to build a computer that is mid range around for gaming. I will be using this on a 24 inch monitor. My budget is probably around the 1200-1300 range.
This will be my first ever attempt at building a computer so I will be quite a noobie at doing it lol. If you see any mistakes with my build feel free to comment on it, like compatibility issues, etc. Oh yeah, I do not intend to do a overly insane overclock, but probably a medium range (first time overclocker!).
PSU: Corsair TX650W 650W ATX 12V 52A 24PIN ATX Power Supply Active PFC 120MM Fan
CPU: Intel Core 2 Quad Q6600 Quad Core Processor LGA775 Kentsfield 2.40GHZ 1066FSB 8MB Retail Box (I decided to get this over the e8400 because if I get this, my entire order will have free shipping)
CPU Heatsink: Thermalright ULTRA-120 Extreme 6 Heatpipe Cooler LGA775 Heatsink *Fan Not Included* (will use Scythe S-FLEX SFF21F 120MM Cooling Fan 1600RPM 28.0DBA 63.7CFM FDB as the fan)
Thermal Paste: MX-2
Motherboard: Gigabyte GA-P35-DS3L ATX LGA775 P35 1333FSB 1PCI-E16 3PCI-E1 3PCI SATA2 Sound GBLAN Motherboard
Computer Case: Coolermaster CM 690 Mid Tower Black ATX Case 5X5.25 5X3.5INT No PS Front USB Sound Firewire & eSATA
Sound Card: Creative Labs Sound Blaster X-FI Xtreme Gamer 24BIT Sound Card 7.1 PCI Retail Box Bilingual
HD: Western Digital SE16 500GB SATA2 7200RPM 16MB Cache 8.9MS NCQ Hard Drive OEM 3YR MFR Warranty
RAM: Corsair XMS2 TWIN2X2048-6400C4 2GB 2X1GB PC2-6400 DDR2-800 CL 4-4-4-12 240PIN Dual Channel
GPU: Galaxy GeForce 8800GTS 650MHZ 512MB 1.94GHZ DDR3 PCI-E Dual DVI-I HDCP HDTV Out OEM Video Card
DVD Writer: Samsung SH-S203B Black SATA DVD+RW 20X8X16 DVD-RW 20X6X16 DL 18X/12X INT DVD Writer OEM W/ Vista SW
Thanks for your time on reading and commenting on this. Also as a side note, if you want to post links on prices / good deals, I live in Canada so I cannot really buy from US stores.
Thermal Paste: MX-2
