Hello,
I am a noob for LCS. I want to start out easy by buying a case with built in LCS. I look through craiglist and there is a person that sells the Thermaltake Level 10 BigWater 850 GT LCS for $150. It seems to be a good deal, so I buy it from him.
When I bring the case home, these are the missing components below:
- a water block
- hose (3/8”)
- hose clamp
After trying to contact the seller several time (he did not answer his phone), I am looking to buy these missing components. Reading through the stickies on top. It seems to be a bad idea to buy ready-made LCS system. However, I am new, so I just want to start with something simple before going to complex one. The Thermaltake Level 10 BigWater 850 GT LCS is a single loop CPU block. Here is the link at frozencpu:
http://www.frozencpu.com/products/1...l_Tower_Liquid_Cooled_Chassis_VN10031W2N.html
I would like some recommendations for components that will fit with the rest of the LCS. If possible, I would like something with total budget around $50. Here are some components I found online. Not sure if it will work:
Hose
http://www.ebay.com/itm/12-3-8-Wate...11195?pt=US_Water_Cooling&hash=item19e420671b
Water Block
http://www.ebay.com/itm/1-PCS-CPU-W...81032?pt=US_Water_Cooling&hash=item25849a1788
Hose Clamp
Can I just go to Home Depot and buy the 3/8" hose clamp? The hose clamp looks like the normal hose clamp used for my water pipe under my sink.
Thank you all for your help.
- a water block
- hose (3/8”)
- hose clamp
Hose
Water Block
Hose Clamp
