krag, i think its an issue of the metal its made of. im sure that the staple is mostly steel, which doesnt solder well at all. try it with some solid copper wire, im sure you'll have much better luck there.
I am waiting to hear the fate of a celly 1.8 we just replaced at work, if the woman wants to keep it or jsut have us toss it. if she does let us keep / toss it, i would love to try this (soldering on a pin) on it, it looks like a lovely challenge, and if i can pull it off it may make some good guide material, if i can any decent pics with the broken LCD on my camera. or maybe brian will have a macro lense for his D70, and i could get him to get some pics for me, i dunno.
i thought about trying on a P1 i have here jsut for an initial try, and something to do but i dont have any decent work area in here right now, its such a mess.
but i think you need some copper wire to use. hve any cat5 around? some to be sacrificed? thats a common thing and is usually solid copper, except for the extremely cheap stuff. if you have the crimpers and a spare end you could always chop off a short length of it (youll get 8 times the length you cutoff, remember that) and then you can put on a new end and nobody would notice anytihng different lol. then youll have a length of copper wire to use and the solder should stick like magic.
editL i just hope that the pad from the old pin wasnt heated too long and possibly burnt traces inside the cpu, as that would probably be quite a bad thing.
how well did the solder take to the remnants of the pin?
