Hi guys,
I am currently using two 2 DIMM of RAM:
[ RipjawsX ] F3-12800CL9D-8GBXL
Specification
XMP Ready for 1st, 2nd and 3rd Generation Intel Core Processors
Compatible with AMD platform
System Desktop
System Type DDR3
M/B Chipset
Intel P67/Intel Z68/Intel Z77
CAS Latency 9-9-9-24-2N
Capacity 8GB (4GB x2)
Speed DDR3-1600 (PC3 12800)
Test Voltage 1.5 Volts
Height 40 mm / 1.58 inch
Registered/Unbuffered Unbuffered
Error Checking Non-ECC
Type 240-pin DIMM
Warranty Lifetime
Features Intel XMP (Extreme Memory Profile) Certified
Now I am trying to add to more DIMMs below:
F3-1600C9D-16GXM(8Gx2)
Specification
Specifications
Model Number F3-1600C9D-16GXM
Series RipjawsX
System DESKTOP
System Type DDR3
Main Board INTEL
M/B Chipset P67 / Z68 / P55 / Z77
Capacity 16GB (8GBx2)
Multi-Channel Kit Single / Dual Channel kit
Tested Speed DDR3-1600 MHz (PC3-12800)
Tested Latency 9-9-9 2N
Tested Voltage 1.5V
Type 240-pin DIMM
SPD Speed 1333 MHz
SPD Voltage 1.5V
Warranty Lifetime
Fan lncluded No
Features Intel XMP (Extreme Momery Profile)Ready
I can't manage them to work together
Separately these couples works fine.
I've updated my BIOS on my GA-H77-D3H
to the latest version. I've also enabled XMP in BIOS.
Please help me to set advanced channel A/channel B setting
Specification
System Desktop
System Type DDR3
M/B Chipset
Type 240-pin DIMM
Warranty Lifetime
Specification
Specifications
Series RipjawsX
System DESKTOP
System Type DDR3
Main Board INTEL
Tested Voltage 1.5V
Type 240-pin DIMM
SPD Speed 1333 MHz
SPD Voltage 1.5V
Warranty Lifetime
Fan lncluded No
