Looking at buying new ram for my new build, going to be a 17 4770k with a asus max hero board. What is the best ram option for this board. I have heard numerous arguments that anything past 1600mhz is a waste and might not be as fast due to cas. Well since all are in the same price range, besides option 2 (Going for $110 on newegg now) Just trying to see whats the best buy for my set up. Mainly gaming and some rendering as well. The ones that I really want are the 3rd choice in the list. The second choice is almost the same but has 10-11-10 30 2N ($110) while option 3 has 9-10-9-28 2N ($154). Are you going to see a big difference in the two, I believe not and since its almost $50 cheaper now, is it worh getting? I believe in the situation, due to the 1600 9-9-9-24 2N ($149) that these could be a better choice but whats $8 more dollars for a little faster ram that could help out. Doing the math, the 1866 due have faster performance, but we are talking small margins here. Any suggestions on what Ram to look at if these are not the perferred choice. PS I will use a NH-14 cooler (40mm is the clearance according to nh website)
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9D-16GXM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231568
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL10D-16GBXL
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231528
G.SKILL Ripjaws X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-1866C9D-16GXM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231615
