Hi all,
I've done upgrading before but this is going to be my first scratch build and was hoping some more knowledgeable people might be able to help cast an eye over it. The system is going to be used for Unreal Development Kit work and Blender design work.
Motherboard: Gigabyte GA-H87-HD3 Intel H87 Socket 1150
http://www.scan.co.uk/products/giga...-sata-raid-pcie-30-(x16)-d-sub-dvi-d-hdmi-atx
CPU: Intel Core i5-4440 3.1GHz Socket 1150 Quad Core Haswell
http://www.scan.co.uk/products/inte...1ghz-33ghz-turbo-1100mhz-gpu-31x-ratio-retail
RAM: 2 X Corsair Memory Vengeance Black 4GB DDR3 1600 MHz CAS 9 XMP Dual Channel
http://www.scan.co.uk/products/4gb-...600)-non-ecc-unbuffered-cas-9-9-9-24-xmp-150v
GPU: Asus GeForce GTX 760 DirectCU II OC Graphics Card - 2GB
http://www.scan.co.uk/products/2gb-...mhz-gddr5-gpu-1006mhz-boost-1072mhz-cores-115
PSU: Cooler Master 720W RS-720-SPM2 Silent Pro M2 80 Plus Bronze
http://www.scan.co.uk/products/720w...lar-135mm-silent-fan-80-plus-bronze-12v-atx-v
(1) Can anyone see any glaring issues with this setup?
(2) The CPU is rated at Max TDP: 84W and the GPU at 170W. I couldn't find any power requirements for the motherboard. It's going to be running:
-2 x IDE drives 7200rpm
-DVD writer
-some cheapo creative labs speakers
-2 each of these fans:
http://www.scan.co.uk/products/120mm-cooler-master-bc-120-quiet-fan-clear-case-with-red-led-1200rpm
http://www.scan.co.uk/products/200m...0rpm-110cfm-19db-silent-case-fan-with-red-led
Do you think 720W will be sufficient?
Thanks for any advice!
-DVD writer
