Hi guys, im about to start buying parts to build a new computer on a bit of a budget and am unsure as to what to go for in terms of CPU and RAM. I only will be using the computer for fairly light video editing on GoPro studio and also picture editing on Adobe lightroom. I have been looking into harware and have decided that an Intel core i5 would suffice for my build but my debate is to go for a 4690k haswell i5 build with DDR3 at less of a cost or do i go for a newer 6600k skylake i5 on DDR4. I cant figure out if its worth spending the extra money on the newer 6th gen skylake with DDR4 or if the haswell build with DDR3 would be more than enough of a capable build bearing in mind there both quad core and 3.5GHz base speed. Any advice would be much appreciated and i hope to hear from you guys soon!
Links to the 2 processors:
https://www.scan.co.uk/products/int...z-turbo-6mb-cache-1150mhz-gpu-35x-ratio-91w-c
https://www.scan.co.uk/products/int...ghz-base-39ghz-turbo-1200mhz-gpu-88w-cpu-plus
Thanks, Brad.
Thanks, Brad.
