- Jul 17, 2003
In terms of RAM, you could easily under purchase at 8 GB *IF* the MB has RAM slots that you can install your own RAM. I stayed with DDR4 for the higher speed from DDR3 and lower cost from DDR5. Buy all the 32 GB you want. It's probably cheaper to buy it seperate anyway. Just do your homework after you buy the computer to match size and speed. To give yourself an idea of costs, plan to buy an Intel CPU and look at dual channel RAM kits. This will ball-park you for what you want. Note: AMD compatible RAM can be more fun to find and will cost a few extra dollars. Nothing too bad but the very cheapest Intel compatible RAM will be really cheap.
