MOBO INFO NEEDED ON AN ASUS A7 PRO
jeff_harrison_344
Senior Member
Does this mobo run at 100Mhz FSB or 133Mhz FSB.
ANd if it runs at 100, will I notice a diff goin from 133 back down to 100?
the A7Pro is the A7V without the Promist ATA100 controller. it uses the same KT133 chipset as the A7V so that means it only runs at 100mhz fsb and cannot reliably do 133mhz fsb...
the A7Pro is the A7V without the Promise ATA100 controller and therefore, it runs on a 100mhz fsb as being limited by the KT133 chipset.
yes...you'll notice a big difference when you have a KT133A and go back to KT133 (like 133mhz fsb back to 100)...
