Hi Guys,
I've looked on a variety of forums for information relating to this. I seem to have made the dubious choice of an Asrock 970 Extreme3 mobo which I have since discovered has a 4 + 1 power phase design which makes it pretty poor when considering overclocking. I have the following build:
CPU
AMD - FX-8320 3.5GHz 8-Core Processor
Motherboard
ASRock - 970 Extreme3 R2.0 ATX AM3+ Motherboard
Memory
Corsair - Vengeance 8GB (2 x 4GB) DDR3-1866 Memory
Storage
Samsung - 840 EVO 120GB 2.5" Solid State Drive
Video Card
Sapphire - Radeon R9 280X 3GB Dual-X Video Card
Case
NZXT - Phantom 410 (Black) ATX Mid Tower Case
Power Supply
EVGA - 500W 80+ Bronze Certified ATX Power Supply
£58.95
Nothing spectacular I can appreciate but I have no issues playing games so it does me just fine. I do however wonder whether my current MOBO is holding back stock performance as I have heard some horror stories!
In terms of overclocking, I have pressed X to enable X boost but the system crashes after about 5 minutes unfortunately which is line with what people have said about the power phase and lack of stability.
I wouldn't want to spend out a huge amount on an upgrade, but I do feel replacing the MOBO will allow me to safely squeeze out a fair chunk of performance without comprising too much the longevity of my rig.
I would say budget wise something along the lines of £75 - £100 would be my limit. Obviously any cheaper boards that offer the ability to sensibly overclock without going over the top would also be welcomed.
Please let me know if you have any questions or suggestions!
Many thanks!
Marc
CPU
Motherboard
Memory
Storage
Video Card
Case
Power Supply
£58.95
Many thanks!
Marc
