- Oct 29, 2010
- Loveland, CO, USA
I have a question here. I have heard it before, and no doubt will hear it again, the concept that increase thermal mass (in this case water) will not add overall cooling due to said thermal mass reaching equilibrium (balance). This is a very loaded statement and for sure not one that would always be true. It is at best a statement based on relativity to the conditions being present that would bring about a stabilization in both the heat sources and the thermal mass. Induce any variable such as overclocking, under-clocking, fan control, pump speed, ambient temps in and outside the case, and no doubt many more, will and do effect any equilibrium in any given loop. For instance, let us say we are going to run a 15 minute CPU benchmark at high overclock. We have just enough thermal mass, and just enough cooling capacity (flow, fans, fan speed, radiator(s), waterblock(s), ambient temps, and unnamed others) to hold temps just below the CPU's max temperature. You run the test and get your score.1. More water does not equal more cooling. It just means that it will take more time to reach an equilibrium is all. But regardless if you have 3 cups or 5 cups of water, if your max temp is 80C, it will remain 80C (of course assuming all other variables remain the same) but just take longer to reach that value (and depending on the amount of liquid added, not much longer).
2. The (only) point of a resivoir in a loop is to make sure the pump has an adequete amount of liquid being fed to it. A res is not required in a loop though.
3. In most cases, assuming adequete flow, which may not happen in THIS case, adding rads is what helps cooling.
Mor7 was spot on in this thread.
Holy cow... this misinformation was on an incredibly dead thread AND you called the guy that actually helped in this thread a 'jerk-off'.
So, to say increasing or decreasing thermal mass will have no effect on this, is really misleading. Take away half the thermal mass (smaller reservoir) and see what will happen. We all know what will happen, so why do we say more water in a loop will not help, when obviously it will given the right set of circumstances. Also, with more thermal mass, temps over time will without a doubt be lower then they would with less thermal mass. It would all depend on amounts of thermal mass and amounts of heat source. The ability to dissipate (get rid of) the amount of BTU's into open air, would not be altered by more thermal mass, but the effect of ability to keep the CPU cooler is absolutely based in part on thermal mass. Get crazy, use a pond for your reservoir, or use a 8oz. reservoir. As long as both started at the same water temperature, you could run any kinds of test you care to, and you will find the CPU temps will always be colder with a large enough reservoir of water.
So, maybe we ought to stop saying the volume water really doesn't matter, when it absolute does if it is too small an amount.
BTW - This is not meant to debate what you said, as you said it very well and in fact are correct. What happens alot though is people too often misstate what actually does happen with more or less thermal mass in a cooling system. Without sufficient quantities of thermal mass, no cooling system would work anywhere close to efficient, whereas with greater and greater thermal mass, efficiencies will always go up, ad infinitum.
OK.
-Rodger
