- Oct 26, 2011
- Oregon, USA
I am realizing that the 4+1 VRM isn't exactly a feature on my motherboard. It was fine when I was running a first gen Phenom X4, but now that I upgraded to the 1100T something needs to be done. I don't have the budget to upgrade to AM3 board with 8+2.
On my ASUS M4A785-M motherboard there is no VRM/MOSFET heatsink or any form of cooling whatsoever except ambient air and maybe an unintentional breeze from the CPU sink/fan. There are also no holes for attaching a aftermarket heatsink with pushpins.
I have devised a plan to purchase 2 EnzoTech MST-66 MOSFET heatsinks and through some modification make them fit within the area needed, but the problem I am having as far as attaching and anchoring the heatsinks go, is what to use.
Will a thermal tape be durable and strong enough? is there any thermally conductive adhesives I could use that are not electrically conductive (just to be safe)??
I also plan on attaching a couple 25mm fans to the sides of the heatsinks if I can anchor them well enough.
Any help/ideas/experiences would be greatly appreciated! Thanks!
