- Aug 3, 2010
Good luck finding thermal tape or adhesive for sale, I tried just about every computer shop I could find and none of them sold it.
Some good quality thermal adhesive would be ideal if you can find a shop that sells it, and the adhesive tends to stick better than the tape does.
25mm fans are going to be extremely noisy to even move a small amount of air, so you'd be best off improving your case ventilation instead. Maybe cutting a hole in the side of your case and mounting a 120-140mm fan on the side blowing onto your motherboard would be the way to go.
Try googling thermal tape and plenty of places sell it..
