Hi, so I’ve had this board for a few months and it’s been fine but when trying to install an ek backplate for my water block I think it was to tight I I might have broke something. On the EZ bug lights it uses to show errors it usually goes cpu- dram-vga-boot. Each light will come on then go off in that order. Now both cpu-dram come on together then go off together and vga- boot do not come on. I’m just getting black screen but all fans and led’s are on. I have another board I can test my gpu but I don’t think that’s the problem. I need to know if it’s a cpu or motherboard fault so i can buy a new one.
Ive tried reseating ram, gpu and cpu block. Resetting my bios and ram in different slots
It’s an am4 b350 ryzen 5 1600
