I should get around to making a sig but I have a bunch of machines and I just don't care all that much.
Previously this setup was "the spare" computer that my wife or friends would use to game on and that was pretty much it.
Old Setup:
Phenom II X6 1100T Running at 4ghz with turbo off
Corsair big o'l nasty heatsink duno which model got it from a friend.
M4A89GTD PRO/USB3
2 x 4gb G.SKILL Ripjaws DDR1333 9-9-9-24
OCZ Agility 2 60GB
Saphire 6950 flashed to 6970 (never had any problems with it)
OCZ StealthXStream OCZ600SXS 600W
New Setup (now going to be my main pc)
Phenom II x6 1100T running stock
CM V8
GA-990FXA-UD5
4 x 4gb G.SKILL Ripjaws DDR1333 9-9-9-24
Kingston SSD Now V+ 128GB
Same Saphire 6950(70)+ 6950 2GB that isn't unlockable
Corsiar 850W PS
When I initially swapped the parts I thought about trying to see how far I could overclock the x6 in the new board but my friend got home and wanted to play some LoL so I figured why not.
In the game it would lock up, but the mouse would still work. Would be totaly frozen for about 10 seconds (just long enough to get killed btw) and then go on normally. Then it BSODed.
In troubleshooting I removed 2nd video card, upgraded the bios to F3, turned off turbo. Verified good contact from heatsink to cpu, ran windows memory test, installed latest drivers and then ran Prime for about 15 min. All of which passed fine.
Launched the game, started playing thought everything was fine and figured it must have been the bios or something. Then after about 15 min of playing it froze again. Then was fine for a while and then locked up again. Then after only a few min a BSOD with a dif error. Before it was STOP: 0x0000001 this time it was 0x00000116 atikmpag.sys
So I swapped out the other graphics card and then got the same issue.
Both of those cards were rock stable before. As was the CPU and half of the current memory.
I did notice that the new memory (even though its the same model) has a different heatsink.
So I'm basically thinking its either the memory, (which it could be some how that I'm now using 4 slots and the cpu doesn't like it I suppose) or the motherboard.
Thoughts? Anybody know a specific test to see if it could some how be the memory?
Tonight I'll probably remove the new ram and test and if that doesn't work I'll swap everything back over to the old motherboard and see if it is stable.
Oh I should add that it wasn't only LoL that had issues. It was also 3dmark and SCII
Old Setup:
M4A89GTD PRO/USB3
OCZ Agility 2 60GB
CM V8
GA-990FXA-UD5
Corsiar 850W PS
